Dash Removal
https://www.slantsix.org/forum/viewtopic.php?t=10683
Page 1 of 1
Author:  Guest [ Mon Oct 18, 2004 2:50 pm ]
Post subject:  Dash Removal
I'm in the process of removing the dash from a 1972 Dodge Dart, however, the bolts located around the gauge cluster i can't seem to get to. I tried removing the gauge cluster but the the column was quite in the way, and after unbolting the column, it doesn't hang low enough. What do I do?
Author:  textoad [ Mon Oct 18, 2004 3:13 pm ]
Your almost there. Remove the bolts at the firewall then the column will drop lower.
