It is currently Wed Jun 10, 2026 12:39 am
 Post subject: alternative alternator ?
PostPosted: Sat Nov 06, 2004 7:29 am
Car Model: '63 Dart GT Convertible
Hey,got a ?. If I wanted to use an alt. to generate power for an application other than on a vehicle, how would the wiring need to be done? Let's say off a car, can I power a 12volt headlight using an alt? If so, how would I wire it? I know someone will know this.
ifyoubegintothinkyou'relosingcontrol...it'salreadygone
PostPosted: Sat Nov 06, 2004 5:53 pm
On the car or off the car the wiring will be the same. You will still need a regulator, alternator, and some means of spinning the alternator at sufficient rpm. You need to get it going at a good 1500-2000 rpm rotor speed before it will put out.
I'm not 100% positive but I believe you still need a battery as well when initally starting the system, then it may be removed. But if you do take the battery out, you have to be careful not to exceed the current rating of the alternator or else you will blow out its diodes quickly.
 Post subject: reply
PostPosted: Sun Nov 07, 2004 6:54 am
Thanx , that tells me I can't do what I wanted to do.
PostPosted: Sun Nov 07, 2004 7:49 am
I had an uncle hook up a car alternator to his windmill to keep some car batteries charged underneath his house. They fed some 12V lights he got off an RV and placed in his kitchen, bathroom, etc., where they didn't need to burn continuously. Or was that a generator off an older vehicle?
Can't remember.
Jerry
PostPosted: Sun Nov 07, 2004 8:47 am
You'll need some voltage to excite the field in order to get current out. That' what the voltage regulator controls.
