It is currently Wed Nov 11, 2026 5:11 pm
PostPosted: Sun Aug 14, 2005 8:46 am
I'm getting a loud squeel occasionally at idle when the AC is on. I have a new idler pully, reman compressor but stock original AC clutch (might be the problem), reman power steering pump and reman alternator. It sounds like the power steering when the belt is a little loose. But I can't tell where it's coming from. Also the AC belt up top wobbles up and down quite a bit with the AC on. How tight should the belts be? I think I have them set about right. Maybe a little on the tight side. Not too tight though. Also I believe these twin piston compressors run a little unevenly don't they causing a bit of wobble on the belt? Any ideas would be appreciated.
Thanks.
Sweet Emotion
PostPosted: Sun Aug 14, 2005 9:03 am
Sounds like belt squeel. I'd tension all the belts first to see if it goes away. You shouldn't get a lot of deflection from the belts when you push down on them, if you do they need tightened. Actually seeing a bump in the belt probably means it needs tensioned or replaced, sounds like it sat in one position for awhile and has a permanent pulley impression.
63 Valiant 200 Signet Convertible 170/
63 Dart, 225/
68 A100 Pick-up 225/
2006 Mitsu Raider Quad Cab (Dakota) Mopar 4.7L
1992 Dodge Stealth RT (My Mid-Lifer) 3.0L 24V
PostPosted: Sun Aug 14, 2005 9:10 am
The belt setup with the V2 compressor on the Slant-6 is not the best engineered in the world; you really need to reef on the idler pulley to get the belt good and tight. Some slant-6 installations had a belt-top idler pulley located just to the passenger side of the compressor to increase belt wrap on the compressor clutch; see if you can find one of those. Make sure not to use a small-diameter V8 clutch on your slant-6 application; you really need to have the large-diameter unit. I like These '76-up style units with the inertia ring (and you can't beat the price...!)
Also make sure to use only name-brand, top-quality belts. Gates, Goodyear or Dayco.
PostPosted: Mon Aug 15, 2005 7:38 am
Does that clutch on e-bay use a v-belt? I can't tell from the picture. Mine is the stock factory 1974 type. Are the '76 and up different? And will it be a direct bolt on? Also how much deflection should I get when I press on the belt?
Thanks.
Sweet Emotion
PostPosted: Tue Aug 16, 2005 6:28 pm
Yep they use a vee-belt. Serpentines were introduced long after the V2's demise.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Wed Aug 17, 2005 9:12 am
Does that clutch on e-bay use a v-belt? Mine is the stock factory 1974 type. Are the '76 and up different? And will it be a direct bolt on?
Yes, yes, and yes.
Depends where you press on it!
Users browsing this forum: Bing [Bot] and 5 guests
