It is currently Wed Jun 17, 2026 8:02 am
PostPosted: Mon Sep 12, 2005 1:37 pm
Well.......the new Valaint motor is almost ready to go.....just driveshaft, shifter , hood and fluids to go.....
I add 5 litres of oil,,,,and went to check the level,,,,and oops!...I hadn t installed the tube and stick yet....
Guess what! I used a truck block!,,,,the dipstick goes through the pan!
OK OK lets not panic,,,,there is what looks to be a plug where the car tube sould go. I would need to remove the motor mount.....the plug has a funny head....or is it casting flash?
Am I drilling a hole...or removing a plug?
 Post subject: Let me check
PostPosted: Mon Sep 12, 2005 2:13 pm
Sound of me running outside.
Hood slams shut.
Mine looks like a cap, I can slide my fingernail under the edge, but didn't try to pull it out.
Not sure if we've got similiar year motors (mine is a 71 or 72 truck motor) , but mine is a cap.
Good luck, hope to see you at Indy
1980 Aspen 225 super six
PostPosted: Mon Sep 12, 2005 2:36 pm
It's just a cap. It slides in like a dipstick tube vise grips and a little caution should remove it.
PostPosted: Mon Sep 12, 2005 2:56 pm
Yippee!,,,,,mebbe I better go pull it out before I yippee.
Thanks dudes!
PostPosted: Mon Sep 12, 2005 7:57 pm
In the end,,,I had to drill the sucker for a roofing screw and pull it out that way,,,,jeesh! It seemed to be made of soft stuff,,,too soft for vice grips.....easy to drill. Done....
PostPosted: Thu May 31, 2007 6:09 pm
I ran into this problem as well. We are almost done with the restoration of my girlfriends 72 scamp and I went to install the dipstick and there was no hole!!! The motor is out of a truck with a casting date of 83. It has the boss for the dipstick hole but i'm not seeing any plug.
Did the late model truck blocks have a plug or will I have to drill? I was thinking about getting a truck pan and welding the section for the dipstick into a car pan. If I do have to drill it out is there anyone that has the measurements and the correct angle so I can do it right the first time?
http://s88.photobucket.com/albums/k199/ ... 2%20scamp/
www.forabodiesonly.com
