It is currently Tue Dec 23, 2025 2:26 am
PostPosted: Mon Nov 21, 2005 1:58 pm
ive heard that around 80' chrysler switched to the hyraulic lifters..etc.
i have a mystery engine that's from 67'-mid70's and i want to put in a custom solid grind from comp cams. did chrysler only put in the hydraulic cams in around 80' or were there some in before that in earlier years?
thanks
PostPosted: Mon Nov 21, 2005 2:04 pm
There was a small-scale production test of hydraulic-cam slant-6s in the 1978 model year, then no more until 1981, when all slant-6s went hydraulic. So, all 1960-1977 slants are solid, the vast majority of 1978s, all 1979s and all 1980s are solid. A few 1978s and all '81-up are hydraulic.
 Post subject: cams and lifters..
PostPosted: Mon Nov 21, 2005 7:29 pm
how can you tell which is which on the lifters?
PostPosted: Mon Nov 21, 2005 8:21 pm
Easiest way is remove valve cover - if rockers have adjustment screws its solid if not then hydraulic.
 Post subject: solid lifters
PostPosted: Mon Nov 21, 2005 8:31 pm
soo i took the valve cover off and sure enough adjustable lifters..so i have to assume the engine is pre 1980 right ?
PostPosted: Mon Nov 21, 2005 9:00 pm
Yep, correct.
 Post subject: plugs
PostPosted: Tue Nov 22, 2005 5:06 am
Thanks Dan...i thought I read the smaller spark plugs were used after 1980..this engine has the small plugs but obviously has solid lifters..i posted on the board for information on identifying the block but i got no response..its listed as "engine numbers"..if you get a chance id appreciate your input..thanks..Mark
PostPosted: Tue Nov 22, 2005 11:42 am
Small spark plugs started for '75.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 9 guests
