It is currently Fri Jan 02, 2026 2:50 am
 Post subject: gas gauge
PostPosted: Mon Feb 20, 2006 3:10 pm
Does anyone know if there are any after market gas gauges that work in an early A body?
PostPosted: Mon Feb 20, 2006 3:12 pm
Car Model: 1962 Lancer 770
Bing do you know what the source of the problem is on yours? What have you checked already?
I don't know of a drop in replacement, but maybe laysons has it.
PostPosted: Mon Feb 20, 2006 5:48 pm
I've spent many hours mulling over this very issue. SHort of designing an complete new panel and going to all aftermarket gauges I don't think there's an esthetically acceptable way to do it. You could certainly mount a separate gauge in a "pod" and mke it work. The gauge you need should responf to a 73 (or maybe 78?) ohm empty, 10 ohm full sender. That is the system used by Mopars and most Fords and all the instrument makers have them.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Feb 20, 2006 6:04 pm
Before replacing the gauge, you may want to verify that the gauge itself is bad (if you haven't already). The wire leading from the sender to the gauge on my girl's Dart is damaged somewhere and likes to frequently cause the gauge to show an empty tank. It's gotten to where the gauge no longer shows fuel at all, no matter what she does, so if we get a chance soon I'm going to help her route an entirely new 16AWG wire back there in hopes of fixing the problem.
PostPosted: Mon Feb 20, 2006 6:20 pm
The sending unit HAS to be grounded. It is kinda strange but the bare steel gas tank doesn't ground to the body good enough for the gauge to work properly.
PostPosted: Mon Feb 20, 2006 7:35 pm
Time to make a ground wire! :P
PostPosted: Mon Feb 20, 2006 8:31 pm
Well I´m also interested in a aftermarket fuel gauge, no matter how many hours I spend checking, re-wiring, paying to get the f**** gauge to work and buying new sender units, my efforts get me to the same point, bad readings.
I can fill the tank, drive 10 meters, shut down the car, restart and the gauge marks 3/4 and everytime I start the car the gauge reads lower until it reach 1/4.
I truly think that fuel gauge is garbage now.
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Wed Feb 22, 2006 2:12 pm
you could get a custom gauge cluster like mine.....then you can have whatever you want.
:D
PostPosted: Thu Feb 23, 2006 12:06 am
:D
Pics please.
PostPosted: Thu Feb 23, 2006 2:12 pm
I'd love to post pics, but I no longer have a website up, but I CAN email a few of the prototype to you if you are interested.
send me a PM if you want to get an email from me.
dakight has seen them already too.
PostPosted: Thu Feb 23, 2006 5:36 pm
Indeed I have and it looks good.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Feb 24, 2006 2:14 pm
thanks dakight, I appreciate that.
jopapa, your pics are on their way-
PostPosted: Sun Feb 26, 2006 11:17 am
Well the gaue is now 40 years old, it was built as cheaply as possible, and you are complaining about problems. You are lucky it even works...
