No Cranking - Key ON pegs ammeter...
https://www.slantsix.org/forum/viewtopic.php?t=16342
Page 1 of 1
Author:  GoodysGotaCuda [ Sun Feb 26, 2006 4:43 pm ]
Post subject:  No Cranking - Key ON pegs ammeter...
Well i got my slant running today. Ignition switch was working fine. When i first got the car it was doing what its doing now...no cranking - pegging the ammeter. i fiddled around witha few things and it worked, didnt think much of it...worked all afternoon. And now i have nothing again.
Key on pegs the ammeter and i can hear almost like a spark in the column. I pulled the steering wheel and i cant see any signs of something going wrong in there...what can i do to troubleshoot this?
Thanks
Author:  argentina-slantsixer [ Sun Feb 26, 2006 7:01 pm ]
if it pegs the ammeter sure it's a big mean assed short... check your wiring under the dash and into the engine bay (especially the alternator and voltage regulator area.... i compressed the VR hot wire one time and I melted some wires :roll: )
Author:  mcnoople [ Mon Feb 27, 2006 6:48 am ]
Does your battery positive cable goes straight to the starter like it is supposed to?
Author:  KBB_of_TMC [ Tue Feb 28, 2006 10:32 am ]
Post subject:  ammeter pegs
You know, if your engine had either no or a very poor ground, when you cranked you'd float the engine at near battery voltage - then the current would take any & every path including through the ammeter open to it. That current probably wouldn't be close to turning the starter, but could damage lots of things along the way.
