It is currently Fri Jan 02, 2026 6:11 pm
PostPosted: Sun Feb 26, 2006 4:43 pm
Well i got my slant running today. Ignition switch was working fine. When i first got the car it was doing what its doing now...no cranking - pegging the ammeter. i fiddled around witha few things and it worked, didnt think much of it...worked all afternoon. And now i have nothing again.
Key on pegs the ammeter and i can hear almost like a spark in the column. I pulled the steering wheel and i cant see any signs of something going wrong in there...what can i do to troubleshoot this?
Daily Driver 72 'Cuda
74 Duster /6
http:www.goodysgotacuda.com
PostPosted: Sun Feb 26, 2006 7:01 pm
if it pegs the ammeter sure it's a big mean assed short... check your wiring under the dash and into the engine bay (especially the alternator and voltage regulator area.... i compressed the VR hot wire one time and I melted some wires :roll: )
Juan Ignacio Caino
PostPosted: Mon Feb 27, 2006 6:48 am
Does your battery positive cable goes straight to the starter like it is supposed to?
 Post subject: ammeter pegs
PostPosted: Tue Feb 28, 2006 10:32 am
You know, if your engine had either no or a very poor ground, when you cranked you'd float the engine at near battery voltage - then the current would take any & every path including through the ammeter open to it. That current probably wouldn't be close to turning the starter, but could damage lots of things along the way.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
