| Slant Six Forum https://www.slantsix.org/forum/ |
| Oddball electrical problem - help https://www.slantsix.org/forum/viewtopic.php?t=16372 |
| Author: | dookdart [ Tue Feb 28, 2006 1:11 pm ] |
| Post subject: | Oddball electrical problem - help |
This happened twice to me...and I can't figure out what the problem is. Maybe someone can help out. Car: 75 S6 Dart. Problem: When starting the car on sub 25 deg. mornings...the following electrical items would not work: blinkers, blower motor, radio and wipers. It runs and drives perfectly. Once at work ( I park inside a heated garage), and the car is in a warm environment....everything works again. This happened twice on very cold mornings. Is there a common junction where these items get power? maybe the cold is causing a contraction in a connector? any other ideas? |
| Author: | Dennis Weaver [ Tue Feb 28, 2006 1:56 pm ] |
I'd suspect the ignition switch. Jiggle it next time. D/W |
| Author: | dookdart [ Wed Mar 01, 2006 2:10 pm ] |
iggy swtich OK! good guess. cold, it just didn't return all the way to ON from the "start" position. I just tapped the key and all is well in the world. thanks again! |
| Author: | Dennis Weaver [ Wed Mar 01, 2006 3:14 pm ] |
No guess. Years of experience! You're welcome. D/W |
