It is currently Fri Jan 02, 2026 6:27 pm
PostPosted: Tue Feb 28, 2006 1:11 pm
This happened twice to me...and I can't figure out what the problem is. Maybe someone can help out. Car: 75 S6 Dart.
Problem: When starting the car on sub 25 deg. mornings...the following electrical items would not work: blinkers, blower motor, radio and wipers.
It runs and drives perfectly. Once at work ( I park inside a heated garage), and the car is in a warm environment....everything works again. This happened twice on very cold mornings.
Is there a common junction where these items get power? maybe the cold is causing a contraction in a connector? any other ideas?
PostPosted: Tue Feb 28, 2006 1:56 pm
I'd suspect the ignition switch. Jiggle it next time.
D/W
If it ain't broke, fix it!
PostPosted: Wed Mar 01, 2006 2:10 pm
iggy swtich OK! good guess. cold, it just didn't return all the way to ON from the "start" position. I just tapped the key and all is well in the world. thanks again!
PostPosted: Wed Mar 01, 2006 3:14 pm
No guess. Years of experience! :lol:
You're welcome. :)
D/W
