It is currently Fri Jan 02, 2026 12:36 pm
 Post subject: gas gage adjustment?
PostPosted: Tue Feb 28, 2006 1:12 pm
When I fill the tank on the 75...the gauge shows 3/4. Is there a way to calibrate it to show Full? add a resistor? gauge works fine...its just off by 1/4 tank! thanks
PostPosted: Tue Feb 28, 2006 1:23 pm
Car Model: 1974 W100; 72 Dart
you can remove the sender and adjust a tab on the float. that's the best way to do it. unless the problem is in the electrical part of the dash.
i'm sure someone can give you the figures you'd need(ohms resistance) to get it to read right and a way to check the gauge itself.
sb
