| Slant Six Forum https://www.slantsix.org/forum/ |
| gas gage adjustment? https://www.slantsix.org/forum/viewtopic.php?t=16373 |
| Author: | dookdart [ Tue Feb 28, 2006 1:12 pm ] |
| Post subject: | gas gage adjustment? |
When I fill the tank on the 75...the gauge shows 3/4. Is there a way to calibrate it to show Full? add a resistor? gauge works fine...its just off by 1/4 tank! thanks |
| Author: | mopar_nocar [ Tue Feb 28, 2006 1:23 pm ] |
you can remove the sender and adjust a tab on the float. that's the best way to do it. unless the problem is in the electrical part of the dash. i'm sure someone can give you the figures you'd need(ohms resistance) to get it to read right and a way to check the gauge itself. sb |
