It is currently Sun Jun 21, 2026 12:26 am
PostPosted: Thu Mar 30, 2006 9:03 am
While digging through the last few remaining parts in the storage crate, I found a triangle-shaped pressed metal shield with an attached fiber gasket. I know it goes somewhere under the front frame rail, but even using the four bolt holes for landmarks, I can't seem to figure out where this shield goes.
Anyone have an idea?
Jerry
PostPosted: Thu Mar 30, 2006 2:44 pm
...goes under the frame rail, driver's side, aft of the front wheel, over the steering linkage.
D/W
If it ain't broke, fix it!
PostPosted: Fri Mar 31, 2006 5:23 am
Thanks, Dennis, I'll crawl under there and take another look.
