It is currently Wed May 13, 2026 10:53 pm
PostPosted: Tue Jun 13, 2006 7:58 pm
I found a 2bbl carb with intake and exhaust manifolds in the salvage yard they were marked 'Aspen' but the guy did not know what year Aspen.
It did not have an Oxygen sensor on the manifold (if that helps).
Would this be a good set up for an 81 truck?
PostPosted: Tue Jun 13, 2006 8:12 pm
Sure. You should only need the intake manifold, carb, air cleaner, choke pulloff assembly, and kickdown linkage. This is a great upgrade for heavy trucks and vans with a slant six.
PostPosted: Wed Jun 14, 2006 9:02 pm
I am not sure all of the kick down linkage is intact, the linkage on the carberator is on the side where as mine is currently on the front.
Our greatest fear should not be of failure but succeeding at something that doesn't matter.
PostPosted: Tue Jun 20, 2006 4:47 pm
Is the intake AL or FE?
PostPosted: Wed Jun 21, 2006 8:19 pm
FE
