It is currently Tue Dec 23, 2025 1:53 pm
PostPosted: Tue Apr 10, 2007 3:39 pm
If I use the stock cam in a rebuild, and a 1 bbl carter carb, minor porting, dual 2 inch exhausts, what would be the highest compression ratio I could use?
I am not looking at racing, just a little more pep and decent economy.
I know a 2 bbl setup is supposta give better economy, but my goal here is to see if using the stock carb and cleaning the head and bumping up compression, plus the better exhaust flow can make little peppier, more economical engine.
Spending $200 on electronic ignition, a couple bills for a cam and more for a 2bbl conversion, 200 for duals, makes for a grand in mods, and you need to save a lot of gas to justify the expense
Or am I wasting my time with this approach?
PostPosted: Tue Apr 10, 2007 3:42 pm
You may be interested in this thread.
PostPosted: Thu Apr 12, 2007 9:47 am
very useful. THanks!
PostPosted: Thu Apr 12, 2007 10:58 am
...cleaning-up the head and bumping up compression, plus the better exhaust flow can make little peppier, more economical engine.
Spending $200 on electronic ignition, a couple bills for a cam and more for a 2bbl conversion, 200 for duals, makes for a grand in mods, and you need to save a lot of gas to justify the expense.
It's not about "saving gas" but more about having a powerful and efficient engine at your disposal.
PostPosted: Fri Apr 13, 2007 6:44 pm
SSRN National Champion
If I know the type car then maybe I can help . I milled a stock head 125 thousand and it will bring it up a point about 9.25 to 1 Ran a lot of Slant parts on the street and strip. But one must remember what there goal is. Thanks Ron Parker :D
Bagels On Juice Im Bamboozled
PostPosted: Mon Apr 16, 2007 4:13 pm
It is a 64 Dart wagon, 904, 2.76 rear.
PostPosted: Mon Apr 16, 2007 4:24 pm
Probably the most bang for the buck would be a rear end swap. A 3.23 would be a lot spunkier on the street without totally clobbering your mileage.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Apr 16, 2007 6:13 pm
I would leave everything on the engine the same. The 71 thru 77 cam shaft was the best production camshaft and I would use that. If the engine is in good tune with points I would not change it. Mill the head 125 thousand and clean up the ports and yes Dakight is right A 3.23 gear change would pick it up in performance and probally gas millage Thanks Ron Parker :D
Bagels Juiced Im Bamboozled
PostPosted: Mon Apr 16, 2007 6:16 pm
'71-'80.
True...if you make sure to install it in some position other than "retarded" (factory spec) or "random" (factory production). :shock:
PostPosted: Mon Apr 16, 2007 6:25 pm
Thanks Dan for that info. You keep straighting out my dum azz. Thanks Ron Parker :D
Users browsing this forum: Bing [Bot] and 13 guests
