It is currently Tue Oct 13, 2026 9:00 pm
PostPosted: Tue Jul 31, 2007 7:42 pm
Site Admin
I've got my spring, valve and plug sitting here next to the keyboard.
Is there a way to measure the spring for a go/no-go check? I've got an obscure Linux installation going right now, so can't view my FSM. :(
CJ
PostPosted: Tue Jul 31, 2007 7:46 pm
Stick a ¼" nut in the threaded cap so as to push a little harder on the spring and just be done with it :-)
PostPosted: Tue Jul 31, 2007 7:49 pm
Site Admin
Highly scientific.... :shock:
Who are you, and what did you do with Dan? :lol:
Probably be OK doing that. Shoot, the new engine is almost finished anyway!
CJ
PostPosted: Tue Jul 31, 2007 8:12 pm
Site Admin
It seems to be happy now. Reminds me of setting the action on my strat with a couple of pennies under the neck. :shock:
Long as it works! Thanks Dan.
Now to dig my spare head out of the pile. It needs to go up to the machine shop for mock up.
CJ
PostPosted: Tue Jul 31, 2007 10:26 pm
The good news... the SL6 oil pump is outside of the oil pan and the relief valve plug is easy to remove when the engine is installed.
I give the relief valve spring setting a fast "best guess" and then get the engine running. Once I see the oil pressure, I adjust the spring tension to get the pressure I want.
Users browsing this forum: Bing [Bot] and 5 guests
