Double Row Timing Chain--Worth the effort?
https://www.slantsix.org/forum/viewtopic.php?t=25929
Page 1 of 1
Author:  Daddiojoe [ Mon Nov 19, 2007 5:57 pm ]
Post subject:  Double Row Timing Chain--Worth the effort?
I'm planning on installing a new Erson RV camshaft in my truck and wondered if it would be worth the $ and effort to put a double-row timing chain on it. I did manage to score the crankshaft gear a while back. Where can I get the cam gear? It's the same as one of the big blocks, isn't it?
Joe
Author:  Joshie225 [ Mon Nov 19, 2007 6:02 pm ]
Crank gear and chain are the same as a big block, the cam gear is unique to the slant.
If you're using stock valve springs and don't anticipate running 200k miles before opening the engine again I feel a silent chain set will serve just fine.
