It is currently Mon May 25, 2026 4:05 pm
 Post subject: bbd float
PostPosted: Wed Dec 05, 2007 3:26 pm
whats a good way to set/check the float, im more used to the ol' flip over checks on other carbs
i got a sweet bog im tryin to lessen.
vacuum 20" at idle dont member timming, but rember playin wit it wit no results. accel pump pumps fine, manual choke helps, but only so much until it blocks air entirly. bog is present even warm, but i have also seen black smoke out the back... which makes me wanna check floats, but there weird design to me...
PostPosted: Wed Dec 05, 2007 3:35 pm
the bog is less with the choke on? If so youhave a vacuum leak.
PostPosted: Fri Dec 07, 2007 1:12 am
ok then y the 20" vacuum...
PostPosted: Fri Dec 07, 2007 6:29 am
How's the pump shot?
PostPosted: Fri Dec 07, 2007 2:12 pm
accel pumps fine
PostPosted: Fri Dec 07, 2007 2:42 pm
How well is the distributor's vacuum advance working?
How "quick" is the mechanical advance?
PostPosted: Sun Dec 09, 2007 10:23 pm
the bulb in my T light is out so im not sure. i do know my dist has a lil bit o play in it when u grab it wit capped
PostPosted: Tue Dec 11, 2007 1:22 am
so slow mech advance would be faulty springs or just crap in there. can u get rebuild kits for stock dists
PostPosted: Tue Dec 11, 2007 1:24 am
dbl post ignore
Users browsing this forum: Google [Bot], volaredon and 3 guests
