It is currently Sat Dec 27, 2025 8:34 pm
 Post subject: carter bbd problem
PostPosted: Wed Apr 09, 2008 7:50 pm
today i was loosening my fuel line on my carter bbd when the fitting behind it broke. does anyone know where to get a new one. it has to have the right size inside hole for the rubber tipped needle to seat to cut off the fuel flow.
PostPosted: Wed Apr 09, 2008 8:23 pm
That's the fuel inlet seat. It comes in a carburetor rebuild kit.
PostPosted: Thu Apr 10, 2008 8:18 am
thanks, i thought it might but none of the part stores around here have one to look at.
PostPosted: Thu Apr 10, 2008 11:55 am
What do you mean, the parts stores don't have WHAT to look at? A carb, a rebuild kit or a inlet nut/needle&seat? That "nut" has come with every carb rebuild kit I have ever bought for a BBD. If they'd pull their PAPER catalogs, often these parts were listed as seperate part numbers, but unless your carb is very freshly rebuilt, youd be better to buy a kit and go thru it anyways.
Users browsing this forum: Ahrefs [Bot] and 9 guests
