It is currently Mon Dec 29, 2025 6:37 am
 Post subject: Rubber Source Needed
PostPosted: Tue Oct 21, 2008 9:09 am
Looking for rear side glass rubber for these fine '64 B-body wagons.
Thanks, Pat.
PostPosted: Tue Oct 21, 2008 2:20 pm
Car Model: 1968 Plymouth Valiant 100
Have you tried http://www.metrommp.com/
PostPosted: Tue Oct 21, 2008 2:23 pm
I checked Metro and Bernbaum; no luck. I think this is probably going to require finding bulk rubber weatherstripping of the correct profile, mitre-cutting one corner and gluing it together.
PostPosted: Tue Oct 21, 2008 2:38 pm
It looks like Paddock has weatherstripping for a b-body wagon but it only goes down to '67. Would that work?
PostPosted: Tue Oct 21, 2008 3:03 pm
You will probably need to use a universal rubber moulding, available from most auto glass shops. You can search for part numbers at http://www.crlaurence.com. Once you have the part number you can go to a glass shop and order what you need.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Oct 21, 2008 3:07 pm
Not even close.
PostPosted: Tue Oct 21, 2008 7:29 pm
I was afraid of that.
'67 is a totally different car. Which is why it's a way more logical car to build. I'm just illogical in my vehicle preferences.
 Post subject: Lol...
PostPosted: Tue Oct 21, 2008 8:23 pm
No, you just are a connoisseur... with discerning tastes...
:wink:
You could always avoid the problem altogether by just giving the wagon to me..... :shock:
No?
Dang!
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Wed Oct 22, 2008 9:33 am
Comedians, the lot of you. I contacted a few of the vendors suggested but I think I'm looking at using bulk material. Maybe I'll cut out a chunk and mail it to them for comparison. Or I won't give up just yet. So many choices.
PostPosted: Wed Oct 22, 2008 10:08 am
Try here:
http://secure.steelerubber.com/homeframes.html
They are probably the most expensive, but their quality and fit is pretty much unmatched. You'll have to search the site to see if they have any of what you want.
Good luck!
obliquely-inclined state of mind
PostPosted: Thu Oct 23, 2008 9:38 am
After much searching for these coveted window seals, I finally tracked down a place that will reproduce beautiful and perfectly matched side window seals with your choice of gold or black lock strip. For a mere $250.00 a set they can be yours. Personally I might just try and re-use my old ones for that price but I thought I would share what I found. http://www.oldmoparts.com/ By the way, don't go e-mailing old Andy because he just "doesn't do that kind of thing" You'll have to call him up and put your request in the old fashioned way.
