It is currently Fri Jan 02, 2026 7:44 am
PostPosted: Mon Mar 29, 2010 7:28 pm
Hi there US Slanters!
I build my new slant for my GTX... and used a 390 cfm double pumper... Do you have any info on a near there main jet info for this? I´m using a 270/280 cam with 108 lobe center line, bigger valves, etc.
I´m using now #58 in primaries and #60 in secondaries... secondaries seem short... (no power valve there)
Here is a small video I took...
http://www.youtube.com/watch?v=6gqfxrzprQw
Cheers!!!!!!!
Men are not jugded by the way they fall, but by the way they get up
PostPosted: Tue Mar 30, 2010 5:05 pm
Car Model: 1964 Dart GT
I have close to the same jetting on mine. Comp Cam 264. I used a lighter seconary spring to get then to open a little sooner which helped with the transition. Hope this helps.
PostPosted: Tue Mar 30, 2010 8:20 pm
Thanks Andy! Mine´s a Double pumper... not vaccum secondaries... but seems i´m near...
PostPosted: Wed Mar 31, 2010 12:12 pm
Cool! Keep me posted on your progress. Good luck!
Users browsing this forum: Bing [Bot], curmudgeon and 9 guests
