It is currently Tue May 05, 2026 9:31 pm
 Post subject: Copper spray
PostPosted: Wed Sep 01, 2010 5:45 pm
Should I use this on the new metal gasket I got? Most metal gaskets(motorcycle) I have dealt with have a film or sealer on them. Or they are layered steel, alum, steel.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Wed Sep 01, 2010 7:11 pm
30 views and not one yay or nay huh? Any suggestion would be great.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Wed Sep 01, 2010 7:55 pm
You have to use something on the shim head gasket and Permatex Copper Spray-A-Gasket is a fine choice. Just used it on the steel shim head gaskets for a good friend's 383 in his Coronet wagon.
PostPosted: Wed Sep 01, 2010 7:57 pm
Not enough info to comment.
No link to the which copper spray?
No mention if this is a stock steel head gasket or some ones custom? or (which brand) composite metal gasket?
PostPosted: Wed Sep 01, 2010 8:09 pm
It is a Mopar steel shim style head gasket not an MLS or custom job. I was refering to the Permatex copper spay... All I really needed to say is that it was a head gasket.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Wed Sep 01, 2010 9:17 pm
NO,If you are running high compression,turbo,nitros you will get different answers.Spray it lightly if you are going bone stock.
PostPosted: Wed Sep 01, 2010 9:27 pm
The stock Mopar head gasket does need a sealer. The "copper coat" should be fine.
PostPosted: Wed Sep 01, 2010 10:38 pm
Should have got it from "the horses mouth" to begin with. lol
Thanks again...
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Thu Sep 02, 2010 4:17 am
Thanks again...
,Cliff
I guess that's better then being called the other end. :o
Users browsing this forum: Amazon [Bot] and 20 guests
