It is currently Fri May 01, 2026 1:08 am
PostPosted: Mon Sep 05, 2011 7:05 pm
Car Model: 87 B150, 1970 Valiant 4-door
anybody know a part # of, and/or a vendor where I can get a dashpot bracket for a 1945?
I'm looking to eliminate the idle stop solenoid it was originally equipped with.
Any suggestions greatly appreciated.
PostPosted: Thu Mar 21, 2013 8:24 pm
Car Model: 1977 B100 Van
Bump!
Any part number? Are they still available?
I'll need one of those brackets (and dashpot) to put on the NOS Holley 1945 economaster that will replace the $#!+ incomplete carb I currently have in my van!
Tried to contact Old Car parts Northwest, no answer so far...
Any other ideas?
"Hey, I like that paint job you got. What they call that--sorta a cross between Piss Yellow and Puke Green, ain't it?" -- Bob Falfa
 Post subject: Nope
PostPosted: Thu Mar 21, 2013 11:30 pm
Holley still offers Dashpots similar in nature to the ones seen on the manual transmission 1920's for their 2300 and 4150/60 carbs....you might try getting a bracket for the current 2300 and modifying it for use with your carb. AFAIK on my 1976 manual transmission carbs (Feather Duster included) they didn't use a dashpot of sorts but used the vacuum actuated solenoid for emissions purposes, although this equipment is listed in the Factory Parts Catalog under "dashpot" for part name and number.
 Post subject: Re: Nope
PostPosted: Sun Mar 24, 2013 6:06 pm
Not sure that bracket could be adapted on a 1945.
Didn't that idle speed solenoid came only on manual cars with A/C?
It's not mentioned anywhere in my '77 FSM though.
Will probably try the carb without dashpot first and see how it goes...
