How to set initial distributor adjustment.
https://www.slantsix.org/forum/viewtopic.php?t=47624
Author:  Hewy [ Wed Jan 18, 2012 3:29 pm ]
Post subject:  How to set initial distributor adjustment.
It is the mounting plate I'm questioning.
One end bolts to distributor body, the other end bolts to engine.
Is there a starting point for setting the distributor bolt ?
As in the middle of the slot arc ? Where do I start ?
Which one is used for final timing light adjustment ?
Help.
Author:  hantayo13 [ Wed Jan 18, 2012 5:22 pm ]
tighten one under dist in the middle....bring engine to TDC on #1 ...install dist so rotor end up pointing at #1 on cap....use base bolt to adjust timing ....if a bit more is needed use bolt under dist .... if not enough remove and move a tooth....if done right both bolts should be near center of slot
Author:  sandy in BC [ Wed Jan 18, 2012 5:48 pm ]
<CORRECT>!
Author:  Hewy [ Wed Jan 18, 2012 6:25 pm ]
Simple enough, I can handle that.
Thanks very much 8)
