It is currently Tue May 26, 2026 11:40 am
 Post subject: fuel pump????
PostPosted: Fri Jan 20, 2012 11:43 am
mid teens truck had been running good...would not start till gas pour in carb.....finally got it running....wont take throttle much over 2000 rpm dies, spits, sputters...remov foot off pedal idles fine..will go to about 2000.... thinking it the fuel pump...replaced fuel filter
PostPosted: Fri Jan 20, 2012 11:49 am
Disconnect the fuel line at the carb and start the engine to see how much fuel flows-out of the line.
You could have some water (now ice) blocking the line / fuel flow.
PostPosted: Mon Jan 23, 2012 12:42 pm
had no gas ...so I installed an electric pump and new line....it runs now
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 2 guests
