It is currently Fri Jun 12, 2026 1:42 am
 Post subject: what color is this?
PostPosted: Mon Feb 20, 2012 12:40 pm
Car Model: 87 B150, 1970 Valiant 4-door
1970 valiant.
inside of trunk lid shown as it's the least faded.
need to tell body shop what color to paint rims. (don't have weather or heated shop for painting myself, and need to drive car out of my garage for some fire inspection this week.)
PostPosted: Mon Feb 20, 2012 12:58 pm
Looks like B5 blue, but if the fender tag is present you can get the paint code from that and be certain.
PostPosted: Mon Feb 20, 2012 1:56 pm
Tough to tell from this photo whether it's B5 or B3. Definitely go to the fender tag -- post a clear, sharp, full-frame photo of it and we can decode it for you.
PostPosted: Mon Feb 20, 2012 7:36 pm
thanks.
would the "EB5"at the beginning of the second line mean B5?
PostPosted: Mon Feb 20, 2012 7:59 pm
Yup! B5. PPG color code 2019.
PostPosted: Mon Feb 20, 2012 8:36 pm
thanks so much
PostPosted: Tue Feb 21, 2012 12:17 pm
Body shop wanted over $600 to paint my rims.
New tires went on unpainted rims.
I'll paint myself in spring with tires & valves on with a lot of masking work.
(If I make a good bench mark, I can remove and reinstall the balancing weights without much difficulty, right?)
PostPosted: Tue Feb 21, 2012 6:16 pm
Ouch!!
Yep...
MRO....
PostPosted: Tue Feb 21, 2012 7:24 pm
You going to paint the wheels blue or black?
PostPosted: Wed Feb 22, 2012 1:37 pm
the factory painted them black, then painted the outside blue (letting it overspray into the holes in the rim so it looks blue all the way through when looking at it from outside the car.)
I'm doing the same.
