It is currently Tue Sep 29, 2026 10:52 pm
 Post subject: Best block for boost?
PostPosted: Fri Jan 11, 2013 12:14 pm
I have a 65 225 and a mid 70's 225, which block would be better for a turbo?
1965 Plymouth Belvedere II Turbo Project - SOLD
2002 Subaru OBS
1995 Lexus LS400 Race Car
PostPosted: Fri Jan 11, 2013 12:17 pm
They will both work fine, but if the 70s one is forged crank, then that one will be slightly stronger.
PostPosted: Sat Jan 12, 2013 1:26 pm
How can I tell if its a forged crank? I really dont want to tear it apart to find out though... and thank you.
2002 Subaru OBS
PostPosted: Sat Jan 12, 2013 2:40 pm
Depending on what you're putting it in, the register on the cranks are different sizes too.
The cast crank came mid 1976. There should be a stamping on the pad under the alternator bracket that will give you the year.
PostPosted: Mon Jan 14, 2013 2:09 pm
Doc's "blocks" article on the main slantsix.org then "articles" page can answer your questions, I believe.
Users browsing this forum: Bing [Bot], Google [Bot] and 37 guests
