It is currently Sun Jun 21, 2026 8:50 am
 Post subject: 225 manifold
PostPosted: Mon Jan 14, 2013 5:42 am
My manifold has 2 hard line fittings on each side approx center. One side it broke off inside and it floats in there but can't get it out. Is these 2 fittings attach to my single barrel carb to suck air? Also can I just tap them and run partial hard line then hose? Thanks Dana
PostPosted: Mon Jan 14, 2013 9:49 am
Even a bad picture can be better than a good description. Can you oblige?
Mike
Recognized by US Federal Courts as a Fuel Economy Expert!
PostPosted: Mon Jan 14, 2013 10:11 am
Intake or exhaust manifold? If exhaust manifold, you likely have one of the somewhat rare (at least in the US) anti-icing air heating systems that ran a tube through the exhaust manifold to pre-heat the air going into the carb. See HERE.
