It is currently Sun May 17, 2026 12:00 pm
 Post subject: Possible Camshaft Scrap
PostPosted: Fri Jan 25, 2013 7:24 pm
Okay so here are a couple of pictures of a camshaft I want to use as a core for a regrind. Does this look like damage and if so does it look to far gone?
This is 2 different spots.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Fri Jan 25, 2013 7:36 pm
6 Pack Dart
looks to me like the casting had some voids.
Richard
 Post subject: Lol...
PostPosted: Fri Jan 25, 2013 10:41 pm
If you ask for something fairly radical, those will be gone after they reduce the base circle and put the steeper lobe on the core...(how do you like 250@.050?)
PostPosted: Fri Jan 25, 2013 10:59 pm
250 sounds a bit radical for this build. I am more in the 236-240 range this time around. Want this to be a streeter.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Sun Jan 27, 2013 9:00 am
That amount of wear is common on a high mileage SL6 cam and it will "grind-out".
More important is wear on the fuel pump eccentric, most regrinders do not like to regrind the FP eccentric so any wear there is a problem.
PostPosted: Sun Jan 27, 2013 10:25 am
Could You chuck it up in a lathe and Do the Fuel Pump eccentric by your self with some Emery cloth?
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 6 guests
