| Slant Six Forum https://www.slantsix.org/forum/ |
| thinking about a cam regrind https://www.slantsix.org/forum/viewtopic.php?t=51475 |
| Author: | Valleyant [ Thu Mar 21, 2013 8:24 am ] |
| Post subject: | thinking about a cam regrind |
I converted my '72 Valiant to super 6 status and milled the head for a 9 to 1 compression ratio. The slant is mated to a 904 torqueflite and it has 2.76 gears out back. Need an opinion on a cam for this combo. Mostly its a daily driver. Gonna try Oregon cams. What grind would work well with my combo and provide more power. thankyou |
| Author: | DusterIdiot [ Thu Mar 21, 2013 3:33 pm ] |
| Post subject: | Agg Ted... |
I would use Aggressive Ted's grind for that range.... Think about ditching the 2.76's for something nicer like 2.94's....too... -D.Idiot |
| Author: | ILMopars [ Thu Mar 21, 2013 4:53 pm ] |
| Post subject: | Re: Agg Ted... |
Quote: I would use Aggressive Ted's grind for that range....
What advantages do the 2.94 gears have? Disadvantages? versus a 2.76?Think about ditching the 2.76's for something nicer like 2.94's....too... -D.Idiot Obviously improved acceleration. I'm curious. |
| Author: | Valleyant [ Thu Mar 21, 2013 5:02 pm ] |
DI, Think about ditching the 2.76's for something nicer like 2.94's....too... -D.Idiot I've got a set of 3.23's. I don't do too much highway driving and when I do it is for a short period anyway. I will look up Teds grind....thanks! |
| Author: | DusterIdiot [ Thu Mar 21, 2013 7:34 pm ] |
| Post subject: | Yes... |
Quote: What advantages do the 2.94 gears have? Disadvantages? versus a 2.76? Obviously improved acceleration. I'm curious.
It's an rpm/cruise thing. Mopar had used 2.94's standard behind their slant six A-bodies with automatics in the late 60's...the couple hundred rpm change gives you the same mileage as the 2.76, without dogging out on acceleration. It's a better overall general ratio for street but doesn't limit you on rpm/noise like the 3.2X's do at 65 mph...-D.Idiot |
