It is currently Fri Oct 09, 2026 5:03 am
PostPosted: Thu Mar 21, 2013 8:24 am
I converted my '72 Valiant to super 6 status and milled the head for a 9 to 1 compression ratio. The slant is mated to a 904 torqueflite and it has 2.76 gears out back. Need an opinion on a cam for this combo. Mostly its a daily driver. Gonna try Oregon cams. What grind would work well with my combo and provide more power. thankyou
 Post subject: Agg Ted...
PostPosted: Thu Mar 21, 2013 3:33 pm
I would use Aggressive Ted's grind for that range....
Think about ditching the 2.76's for something nicer like 2.94's....too...
 Post subject: Re: Agg Ted...
PostPosted: Thu Mar 21, 2013 4:53 pm
What advantages do the 2.94 gears have? Disadvantages? versus a 2.76?
Obviously improved acceleration. I'm curious.
Leela: 1970 Dart 225 CID
Coulmn Shift TorqueFlite
7 1/4" Axle 2.76 Gears
Go ahead and save that weird car, the sedan, the 6 cylinder, the C-Body. If you want a big block musclecar and that's all you care about, your missing the point.
PostPosted: Thu Mar 21, 2013 5:02 pm
DI,
I've got a set of 3.23's. I don't do too much highway driving and when I do it is for a short period anyway. I will look up Teds grind....thanks!
 Post subject: Yes...
PostPosted: Thu Mar 21, 2013 7:34 pm
What advantages do the 2.94 gears have? Disadvantages? versus a 2.76? Obviously improved acceleration. I'm curious.
It's an rpm/cruise thing. Mopar had used 2.94's standard behind their slant six A-bodies with automatics in the late 60's...the couple hundred rpm change gives you the same mileage as the 2.76, without dogging out on acceleration. It's a better overall general ratio for street but doesn't limit you on rpm/noise like the 3.2X's do at 65 mph...
Users browsing this forum: Bing [Bot] and 27 guests
