It is currently Mon Nov 09, 2026 11:15 pm
 Post subject: Engine Startup
PostPosted: Tue Mar 04, 2003 5:24 pm
Hi,
Is is normal for a cold engine to sound kind of cranky, clunky, noisy when first starting until oil pressure comes up? 225 /6 always sounds like a rattle trap until it's been running for a few seconds.
150,000 miles on engine... would a heavier viscosity oil be a good thing for this, or a synthetic, or some other additive? Right now is using 10/30.
Thanks,
Tom
PostPosted: Tue Mar 04, 2003 8:39 pm
Sounds like a worn engine, I would use a thicker oil, 20-50 or 30 wt and even a can of STP or other thick "motor honey" to help fill the gap in the worn bearings.
I never use 10-30 in a California driven SL6
 Post subject: worn motor
PostPosted: Wed Mar 05, 2003 6:36 am
Some 20 50 and a bottle of STP oil treatment should help.
PostPosted: Wed Mar 05, 2003 7:35 pm
it sounds like when u start it, it isnt running all cyl. a first. when i start mine -20 weather it sounds like a diesel until all the cyl. start workin
86 dodge ram w-150
4.10's 4 speed manual
4 inch lift 36's wrapped around weld 15x10 typoons , bored .030, shaved .060, ported, headers, 4-barrel 500 cfm carb, clifford intake& headers, isky racing springs and cam, MP electronic igin,
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
