It is currently Sun Dec 28, 2025 11:52 am
PostPosted: Mon Jul 15, 2013 8:38 pm
I looked around and could not find a 7/16 distributor wrench I was willing to buy. So I went to lowes and bought a "long" handle wrench for 6.50 then proceeded to bend it. Nice thing about the Kobalt brand is they have a line indicating SAE vs Metric that line is PERFECT for heating to bend at.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
 Post subject: Lol...
PostPosted: Mon Jul 15, 2013 8:58 pm
Looks just like my grandfathers...
:wink:
Just not as used and pitted...
PostPosted: Mon Jul 15, 2013 9:01 pm
Lol give it time. I did find my least favorite thing about using it. Burning my hand on the head. Damn thing gets HOT.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Mon Jul 15, 2013 10:36 pm
6 Pack Dart
I drilled a hole in the handle of a cheap wrench and welded a peice of round shafting in the hole then welded a short peice of the rod onto the end to form a T shaped wrench.
Richard
PostPosted: Mon Jul 15, 2013 10:54 pm
I have these in 7/16, 1/2 and 9/16
http://www.mactools.com/Product/tabid/1 ... fault.aspx
PostPosted: Tue Jul 16, 2013 7:18 am
Yeah MiDi I just have a problem paying 50+ bucks for a tool that gets used VERY rarely.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Tue Jul 16, 2013 9:01 am
have bent,ground several wrenches for special use
PostPosted: Tue Jul 16, 2013 9:05 am
Anyone know if the lifetime warranty still holds?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Tue Jul 16, 2013 9:30 am
It is easier to just convert to the later style distributor hold down.
PostPosted: Tue Jul 16, 2013 9:39 am
I agree reed but I was not able to find anyone selling that hold down. I took the earlier style off my existing distributor.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Tue Jul 16, 2013 10:01 am
what does it look like? any pictures? what years are "later style"?
1964 Dart GT
PostPosted: Tue Jul 16, 2013 10:10 am
Here are the two styles side-by-side:
Here are the component parts of the later (more preferable) style:
Here is how they fit together assembled on the motor (use your imagination for the engine block):
Please note that I am missing the o-ring that goes under the plate on the distributor. If you leave this off you get a BIG oil leak.
The metal u shaped thing clamps the ring bolted to the bottom of the distributor to the engine block holding it steady.
I don't know the exact date of the switch in hold-down styles, but I believe it was in the late 70s. Note that the distributor showing the later style is a lean-burn distributor. The ring is a slant only piece (I think, maybe a v-8 would work), but could probably be easily fabricated from flat stock of metal. The clamp from a v-8 *might* work, but try and find a slant six one first.
 Post subject: Er, no...
PostPosted: Tue Jul 16, 2013 10:54 am
These first appear in 1979 model year, so good sources are trucks/vans in the 80's (unfortunately most junkyards pull the dizzies and the claw and bolt go to the wind).
The small block V-8 clamp is too short and wide, so when bolted up it will not clamp in the right area to keep the dizzy in place. The big block clamp has a right angle on it and much more reach, these could be adapted if someone takes 30 minutes out with an angle grinder, cutoff wheel, and a die grinder to make it fit.
FYI.
PostPosted: Tue Jul 16, 2013 12:48 pm
:D Cool! Thanks Reed/DI- Something to add to my "Scrounging List" :lol:
1964 Dart GT
 Post subject: distributor wrench
PostPosted: Tue Jul 16, 2013 2:18 pm
The one Rob recommended long ago is still available for $14ish...
See: http://www.toolsource.com/distributor-w ... 51101.html
