It is currently Mon Nov 09, 2026 11:24 pm
 Post subject: Water pumps
PostPosted: Sat Mar 22, 2003 10:11 am
Is there a "better than stock" h2o pump for the / or is cooling a non issue on a street/strip engine. I was thinking about an electric fan to free up extra hp or would a viscous type fan be a better choice. According to the Mopar 6 cylinder book the MP viscous fan was up to 10hp better than a fiberglass/plastic type fan. Any input will be welcomed.
Thanks,
C-Dog
go fast, turn left, don't screw up.
WWW.Mopardropheadcoupe.com
PostPosted: Sat Mar 22, 2003 10:20 am
I installed an electric fan on my Duster. Works great:
http://ramchargercentral.com/boards/ind ... show;id=19
-George
It's a Slant thing. Even I don't understand.
1974 Duster, EFI /6 soon to be turbo...
Get that Monkay! Get that nasty thing!!
PostPosted: Sun Mar 23, 2003 10:33 am
The factory water pump has a good empeller. The aftermarket pumps I have seen use a stamped 'cookie cutter' empeller. The OEM I have uses a solid empeller with metal between the vanes to prevent back flow. I use a Flexalite black magic fan, but switch to a steel flex in the summer.
Mitch
Users browsing this forum: Amazon [Bot] and 3 guests
