| Slant Six Forum https://www.slantsix.org/forum/ |
| Water pumps https://www.slantsix.org/forum/viewtopic.php?t=5298 |
| Author: | cycledog [ Sat Mar 22, 2003 10:11 am ] |
| Post subject: | Water pumps |
Is there a "better than stock" h2o pump for the / or is cooling a non issue on a street/strip engine. I was thinking about an electric fan to free up extra hp or would a viscous type fan be a better choice. According to the Mopar 6 cylinder book the MP viscous fan was up to 10hp better than a fiberglass/plastic type fan. Any input will be welcomed. Thanks, C-Dog |
| Author: | GunPilot [ Sat Mar 22, 2003 10:20 am ] |
I installed an electric fan on my Duster. Works great: http://ramchargercentral.com/boards/ind ... show;id=19 -George |
| Author: | MitchB [ Sun Mar 23, 2003 10:33 am ] |
The factory water pump has a good empeller. The aftermarket pumps I have seen use a stamped 'cookie cutter' empeller. The OEM I have uses a solid empeller with metal between the vanes to prevent back flow. I use a Flexalite black magic fan, but switch to a steel flex in the summer. Mitch |
