It is currently Mon Nov 09, 2026 11:24 pm
 Post subject: Hp
PostPosted: Tue Apr 08, 2003 9:24 pm
I was wandering about how much horsepower I will be getting if I have 9to1 compression pistons bored .30 0ver I am going to run a 250 duration cam. Is there way to figure this. thanks
Scott Davisson
 Post subject: You could estimate...
PostPosted: Tue Apr 08, 2003 10:17 pm
You could ask someone to run the quarter mile who has a similar rebuild and use one of those 'reverse' dyno programs that calculates HP based on quarter mile times, and a couple other variables...that would get you in the solar system for a guess-timate.
Some of your equation will also depend on exhaust and intake/carb choice.
My duster runs a .020 over 225, 9.22:1 compression, ported/gasket matched the head, Comp cam 252S, Carter BBD, Super Six intake, with stock Feather Duster exhaust pipe, and it's a big improvement over the stock 1 barrel version, but I don't think I'm over 130hp 'net' compared to the 100hp 'net' that it was stock....
good luck,
