It is currently Thu Nov 26, 2026 3:32 pm
PostPosted: Thu Nov 05, 2026 2:17 pm
Hi All, this is Nick Bowman, I used to race with you all at one time in the past. 2007-2009
I recently bought a 73 Dodge Dart 4 door 225 slant 6 auto and got a sudden itch or idea that somehow it would be very cool to run Stock Eliminator with this car, slant 6 powered.
I have no idea how plausible this would even be but im seeing myself fitting into V/SA likely and sitting on a 15.50 quarter mile index.
I really dont see cars running these classes these days. Few and far between i believe.
Is it plausible to think i could get this car to run 15.50 or better with the following:
-8 3/4 4.56-4.88 gear ratio ?
-8" BTE Bolt Together Converter shooting for 4000+ rpm Flash at the hit ? I have a Lifetime FREE Re stall or can acquire parts for adjustments at home)
-custom cam grind NHRA legal (any tips?)
-Cut heads to near minimum
-bore .030 over
-forged pistons with good ring package, file fit
-polish crank
-balance shortblock
-manual valve body in trans torqueflite 904
I have an engine builder dad (not a 6 cyl expert but a genius either way) and a machinist who we very close with and willing to work with us.
How crazy is my idea that this is plausible. I dont expect this to be outrageously expensive but i do plan to spend thousands of dollars to achieve a capable combo, IF this even sounds plausible to you experts.
I am here for your expert comments on this, I would REALLY love to hurt some feelings in stock eliminator powered by a 6 cylinder!
Whats it going to take ?
PS: GREG ONDAYKO if your number has not changed over the years, i may reach out to you sometime. Fortunately, i have an expert like you that is very local to me!
Nick Bowman
1970 Plymouth Valiant Duster 408ci magnum btm/LA top (6.39 DEEP STAGED best 8th) at 3185lbs
1973 Dodge Dart 4 door base 225 slant 6 Automatic.
PostPosted: Thu Nov 05, 2026 3:20 pm
I'll send you my number..the one you have is the old land line # that I no longer have.
Mike Jeffery ran V/SA with an '81ish? Dodge diplomat 2 door.
Mike is not on here and will likley not give much detail as he sold all of his stuff 10 years ago and does not want to be bothered with Slant 6 stuff.
It is possible that there is some documentation on his efforts in the SSRN archives.
I know nothing about NHRA. My stuff is not stock.
Slantzilla knows a lot about such rules etc and he bought many of Mike's old parts and cars.
If you are going to washington twp/ 66 apollo VFD swap we can chat then.
Ultimately I think you want a car that was available with the super 6 from~77-81? For V/SA slant 6 work..
Hopefully others can chime in here too!
PostPosted: Thu Nov 05, 2026 4:45 pm
Hello Nick! And welcome back to the wild side! :D :D We have never met but I remember hearing your name or reading about you in the SSRN. Like Greg, I know nothing about "stockers" but you'll definitely need that 2 barrel to get into the 15's. I think Mike was in the 14's with his car if memory serves me correctly. Anyway welcome to the site and hope to meet up with your sometime. If you build it, we will expect you to race with us sometime! :D :D Rick Covalt
PostPosted: Thu Nov 05, 2026 5:35 pm
Here is a picture of Mikes car,
PostPosted: Thu Nov 05, 2026 5:52 pm
I assume you already have the NHRA Rule Book?
I was going to take a shot with my 76 Dart Lite, but I just don't have the energy anymore.
NHRA tech guy told me to build the car and then bring it to a Divisional Meet, they would tech it there.
They don't want to talk about a car that doesn't exist yet.
PostPosted: Thu Nov 05, 2026 7:04 pm
Thanks Greg, not sure I'll make it over. I might be at my dad's house which is 5 minutes from the fire hall. Right off of 286 1 driveway down from Pfeffer Road off of 286.
Appreciate it, I can reach out sometime.
Anyone out there running 16s with a 1bbl?
Yes- I have a rule book. It actually sounds more plausible for me to add weight and bring the car up over 3300lbs and I can run 16.65 in W/SA. I don't see why I couldn't get the car to run low 16s with a 1 bbl.
Considering I'm going to scream it with 4.56 gear, 8inch high stall converter, manual valve body and some engine work within the rules. My duster weighed 3100+ and ran 17.76 with 3.23 gear and 2bbl intake, 100% stock everything else. Had 1800-2000 stall and didn't even move when launching in the wood!
The 2bbl gave me considerably less gain than the gear swap did. Maybe .05 faster but the gear was roughly 1.3 seconds faster. Imagine going more gear to 4.56 and using every bit of it.
Imagine more compression, legal cam upgrade and bigger bore would be a much more improved gain over a 2bbl feeding a 100% stock combo.
Bigger jet and accelerator pump nozzle to try and eliminate the 1bbl bog...
I almost feel like this car could run as low as into the 16s without engine work, just good converter, alot of gear ratio and a manual valve body and tuned carb. But I was hoping there were plenty of ya who have tweaked a 1bbl.
Probably FEW who have ever ran alot of gear. I will plan to tow this car but drive it if I set it up for NHRA Stock.
Rules V/SA is my class but 15.50 is asking a lot. W/SA would be 16.65 and I would only require an additional 262lbs or so. That's only about 2.5 tenths slower with weight, so if I can run say 16.20 add weight im still likely under the 1665 index and therefore safe to play! There are a few W/SA players running fords that are faster but fewer and further between still.
Believe me if there is a way to do this without spending a fortune I am all in.
I figured this crowd would be thrilled with someone wanted to run a slant 6 in NHRA stock.
I wouldn't be doing it to just do it either, id be doing it with the intentions of winning, whether the car is consistent or not. Bracket racing is what I do. I just want to hurt some feelings with a slant when I do it.
Anyone interested in seeing this happen, feel free to chime in with any info I could use to successfully class this car and run at least a tenth below the index. Eastern half of the US so I won't be expecting western state conditions like Vegas was ! My car ran 3+ tenths slow to the 1/4 mile out there 2 tenths slow in 8th.
Thanks everyone.
PostPosted: Fri Nov 06, 2026 4:09 am
Nick, I'm all for it! Go Go Go!!! But that 1 barrel is gonna kill you in my opinion. All the gear, and long duration camshaft, and convertor is great but it will still only pass so much through the carb. It will probably go like crazy and then hit a wall rpm wise because of a lack of fuel. I would be happy to be wrong and hope you can make it work.
PostPosted: Fri Nov 06, 2026 4:25 am
Back in the '70's I ran stock elimator with a 170. It did run mid 16's, with a 1 bbl, but that was in a car that weighed 2530 lbs. The stock rules have really changed sinse then. We had to run cams with stock lift and dur. Could change the lift rate and lobe time/seperation. stock pressure valve springs, etc.
Personal opinion: Not going to be competitive, with a 225 and a 1 bbl carb.
If you try it, a sugestion. Find as many crabs as you can, and measure the barrel size and venturi size. These carbs are so cheaply made, the specs are all over the place. I had one 1920 carb, that was right at NHRA spec, and was about 2 tenths quicker then my next best.
Just a little story:
The 1st major meet we entered was a "Gold Cup Series" meet a Englishtown nj. The final was my 65 Valiant 170, Z/SA, againt A 67 Ply wgn with a 225 in Y/SA My car won the event. 17.35 at 75.00 mph
The 67 Ply ran 16.93 at 78.53
PostPosted: Fri Nov 06, 2026 5:13 am
Nice to hear from you, Nick. It has been a while! Cool that you want to build a competitive Slant. i might suggest running a 1945 carb if you can. I think they are bigger bore, although more complex than a 1920 or BBS. I had one on my first beater car on a 75 engine and that thing screamed until the throttle shaft wore out... Pretty sure Mike ran far down in the 15s with a 1bbl. Please post cam spec restrictions and I will contemplate a cam profile.
PostPosted: Fri Nov 06, 2026 6:04 am
I got to thinking (I know, dangerous). Being the slant six head is so restrictive, and haveing a 1 bbl carb
I would consider working with the header confiuration, and cam timing to optimize cyl scavining, which will help with intake flow. This would all be "custom" stuff.
PostPosted: Fri Nov 06, 2026 8:55 am
the nhra will have the cam spec.
there used to be cheater cams that were legal but were altered.
i ran one in my 70 challenger 440 car back in the 70's.
PostPosted: Fri Nov 06, 2026 4:40 pm
The cam I ran in my 170, was a custom Lunati "cheater". Had stock lift and dur, (I don't remember the lobe timing specs) faster lift rate (limited by stock spring pressure), and was lashed at .005 and .008
As I understand, the rules, now, the cams don't have to have OEM lift and dur. and spring pressures don't need to be stock, either.
PostPosted: Fri Nov 06, 2026 5:04 pm
In "Stock"?
PostPosted: Fri Nov 06, 2026 6:57 pm
In "Stock"?
Yes. The rule at that time was OEM lift and duration. But you were allowed to change the lobe timing/separation. Also even though the lift and duration were "STOCK" cam grinders would speed up the lift rate to get more area under the curve. However the faster the lift rate the more spring pressure was needed to control the valve, so NHRA required stock spring pressure and assembled hight.. That limited the lift rate.
The last time I looked at a rule book for stock eliminator, the rule for cams was a NHRA published lift and duration, OR stock OEM whichever was greater. I don't know if that is still the rule.
PS: I ran stock in 1974-1976. I quit when NHRA changed the class requirements for Y and Z stock to 4 cyl only. I would have had to run. X/SA at the same weight and HP as in Z/SA
My 65 Valiant model 100 2 dr sdn with the 170/auto was the purfect Mopar for Z/SA. The car needed to be 2527 lbs with the 170 and weighted 2530 with 5 gal gas., and no weight reduction, except for heater and radio delete. The car was quicker with the 904 that with a 3sp stick. As a stick had to run a smaller carb. The auto used the same size carb as the 225. Also the stick gave up torque multiplication and had too much rpm drop from 1st to 2nd. Then I also didn't trust that little clutch.
PPS: I was running a 7 1/4 with a 391 SG and a 22.5x6x13 slick then went to a 23x8x13 slick. M&H Made them special for me.
PostPosted: Sat Nov 07, 2026 9:25 am
IIRC, W is 4 cylinder only. Slants only fit U and V. If you spend a gob of money and work really hard you may get it to run under the index, but the 1bbl in not a good combination.
Build it and possibly you can lobby the NHRA for a horsepower reduction, that will help. Mike couldn't run much under index when he started and got 2 reductions, I believe. At that time there was another Slant car running too, and they worked together for the reduction.
After the reductions Mike went on to hold the national record twice, and got horsepower added back on twice.
Block, head, intake, and carburetor must be correct for the year claimed. There are no intake or carb modifications allowed besides jetting.
Mike spent hours looking for "good" parts. Heads can only have limited machine work done and 0 port/chamber work. You are not even allowed to grind out casting flash or goobers. Any tool mark in a port or chamber is a no-no. You can get creative with the valve job, but it still has to end up within the rule book specs.
Cam must be stock lift, duration is whatever you decide you need. The spring rule has relaxed some.
Mike spent many hours and dollars on the dyno at Bogner's too.
Trans you can rollerize and use lightweight parts, but no transbrake allowed.
Rear can be any factory style Mopar unit, but it must match stock width.
A guy from South Dakota still has Mike's car and it still will run .9 under the index. If you're really serious about running Stock maybe buy the car and go racing. (if Curtis will sell it)
I asked Mike one time for advice on building a Stocker after he retired. His advice was "Don't". :oops:
