It is currently Sat Nov 28, 2026 9:23 am
 Post subject: now what
PostPosted: Tue Nov 11, 2003 2:10 pm
i have the timing set and the gm transistor well grounded and the car fires up runs like a champ then dies. its really buggin me thetransistor is new as is the distributet?i am toatally lost here can anyone help??
thanks
PostPosted: Tue Nov 11, 2003 3:18 pm
does it die when you let off the key?
if so you probably need a new ballast resistor.
PostPosted: Tue Nov 11, 2003 3:20 pm
no it will run for a good 5 sec.s then die??
PostPosted: Tue Nov 11, 2003 5:13 pm
i would adjust the idle screw just to see if I had the idle set to low
PostPosted: Wed Nov 12, 2003 6:43 am
can anyone give me some advise?? time is money!
thanks
PostPosted: Wed Nov 12, 2003 10:14 am
I agree with 70val-- Sounds like a fuel delivery problem. Double check the carb settings. If it still has a ballast, doesn't hurt to change it as well.
-S/6
