Can a Holley 5200 fit on Super Six?
https://www.slantsix.org/forum/viewtopic.php?t=8053
Page 1 of 1
Author:  ET's_Swinger [ Fri Jan 09, 2004 5:31 pm ]
Post subject:  Can a Holley 5200 fit on Super Six?
Is it possible to use a Holley/Weber 5200 progressive 2 barrel carb on a Super Six intake manifold? Or would I have to make an adapter?
I'm kind of curious to see how a Slant would perform compared to when I had one on my Mustang's 200. Also I've never really liked full time two barrel carbs.
Author:  DusterIdiot [ Fri Jan 09, 2004 10:54 pm ]
Post subject:  Can be done...
Here's a quick pic of a super six intake with a Mr.Gasket #1937 adapter, and Holley 5200/Weber Clone out of a Pinto 4 cyl car......You figure out the linkage and tuning:
Author:  ET's_Swinger [ Sat Jan 10, 2004 12:55 pm ]
Thanks for the pic!
The only problem I can see with linkages is getting the kickdown hooked up properly, but I think I'll probably upgrade to a Lokar cable setup for it and throttle.
Tuning shouldn't be a problem, as I think the jets Tom Langdon installs in his carbs are about the right range for a Slant.
