| Slant Six Forum https://www.slantsix.org/forum/ |
| dutra oil gear https://www.slantsix.org/forum/viewtopic.php?t=8160 |
| Author: | RE Jones [ Mon Jan 19, 2004 8:44 am ] |
| Post subject: | dutra oil gear |
| Author: | Doc [ Mon Jan 19, 2004 9:14 am ] |
I have a few of these left so drop me a privet message or email and we can work something out. Price is $35.00 per gear. DD |
| Author: | Rob Simmons [ Tue Jan 20, 2004 7:03 am ] |
Hey Doc, Can you bring one with you when you fly out to go to Gatlinburg? I should get one for our engine that's at the machine shop right now. Rob |
| Author: | Doc [ Tue Jan 20, 2004 8:55 am ] |
I can bring a few of the hardened OP gears with me to Gatlinburg. Drop me a PM (to Doctor Dodge) as a reminder. Thanks Rob, I'm looking forward to meeting you in a couple of weeks. DD |
| Author: | 69dartboy [ Tue Jan 27, 2004 7:16 am ] |
what is the new gear made of (hardened what) and is there anything for the dist. gear?? |
| Author: | slantzilla [ Tue Jan 27, 2004 8:38 pm ] |
Quote: what is the new gear made of (hardened what) and is there anything for the dist. gear??
NAPA used to list an iron distributor gear. |
| Author: | Doctor Dodge [ Tue Jan 27, 2004 9:48 pm ] |
I have the oil pump gear in case hardened (carborized) cast iron and in nickel alloy bronze. DD http://www.dutra.org/pictures/engine/bronze-gear-sm.jpg |
| Author: | 69dartboy [ Wed Jan 28, 2004 7:11 am ] |
i dont think i can use a iron gear at least my cam card said dont use one, earson recomends a alu-bronze gear for the dist is there one? |
| Author: | Doc [ Wed Jan 28, 2004 8:31 am ] |
Unless you have a steel cam, the iron gear will be fine. As for the distributor gear, they are plastic (nylon) so that is not an issue. I think your cam card has info which applies to a Chebby, not a Slant. DD |
| Author: | steponmebbbboom [ Sat Jan 31, 2004 12:03 pm ] |
Quote: I have the oil pump gear in case hardened (carborized) cast iron and in nickel alloy bronze.
Doc, your article doesnt mention the cast bronze gear. How did the bronze gear work out, do you have any success stories?
| Author: | 69dartboy [ Sun Feb 01, 2004 5:37 pm ] |
i have a steel cam, what is there for alu-bronze i saw some on the site listed above but where do i get them and how much $$$ are they |
| Author: | SlantSixDan [ Mon Feb 02, 2004 6:52 pm ] |
NAPA still lists the iron dist gear, it is Echlin P/N DG404. |
| Author: | Doc [ Mon Feb 02, 2004 7:02 pm ] |
Quote: I have a steel cam, what is there for alu-bronze i saw some on the site listed above but where do i get them and how much $$$ are they
You have a steel cam.... You can get a bronze gear from Dutra (Doctor Dodge) or the Cox Boys. They cost about $45.00 DD |
