It is currently Fri Aug 14, 2026 11:09 pm
 Post subject: dutra oil gear
PostPosted: Mon Jan 19, 2004 8:44 am
:) I keep seeing people talk about the Dutra oil pump gear. I have read the article on oil pump gear failure, where do I purchase a couple of these gears at and what is the price?
PostPosted: Mon Jan 19, 2004 9:14 am
I have a few of these left so drop me a privet message or email and we can work something out. Price is $35.00 per gear.
PostPosted: Tue Jan 20, 2004 7:03 am
Hey Doc,
Can you bring one with you when you fly out to go to Gatlinburg? I should get one for our engine that's at the machine shop right now.
PostPosted: Tue Jan 20, 2004 8:55 am
I can bring a few of the hardened OP gears with me to Gatlinburg.
Drop me a PM (to Doctor Dodge) as a reminder.
Thanks Rob, I'm looking forward to meeting you in a couple of weeks.
PostPosted: Tue Jan 27, 2004 7:16 am
what is the new gear made of (hardened what) and is there anything for the dist. gear??
have fun!
PostPosted: Tue Jan 27, 2004 8:38 pm
NAPA used to list an iron distributor gear. :shock:
PostPosted: Tue Jan 27, 2004 9:48 pm
I have the oil pump gear in case hardened (carborized) cast iron and in nickel alloy bronze.
http://www.dutra.org/pictures/engine/bronze-gear-sm.jpg
PostPosted: Wed Jan 28, 2004 7:11 am
i dont think i can use a iron gear at least my cam card said dont use one, earson recomends a alu-bronze gear for the dist is there one?
have fun!
PostPosted: Wed Jan 28, 2004 8:31 am
Unless you have a steel cam, the iron gear will be fine.
As for the distributor gear, they are plastic (nylon) so that is not an issue.
I think your cam card has info which applies to a Chebby, not a Slant.
PostPosted: Sat Jan 31, 2004 12:03 pm
Doc, your article doesnt mention the cast bronze gear. How did the bronze gear work out, do you have any success stories?
PostPosted: Sun Feb 01, 2004 5:37 pm
i have a steel cam, what is there for alu-bronze i saw some on the site listed above but where do i get them and how much $$$ are they
have fun!
PostPosted: Mon Feb 02, 2004 6:52 pm
NAPA still lists the iron dist gear, it is Echlin P/N DG404.
PostPosted: Mon Feb 02, 2004 7:02 pm
I have a steel cam, what is there for alu-bronze i saw some on the site listed above but where do i get them and how much $$$ are they
You have a steel cam.... :shock: :twisted:
You can get a bronze gear from Dutra (Doctor Dodge) or the Cox Boys.
They cost about $45.00
Users browsing this forum: No registered users and 24 guests
