It is currently Fri Jan 02, 2026 4:39 pm
 Post subject: headers
PostPosted: Wed Feb 11, 2004 10:55 pm
thinking of installing clifford headers on my 77 volare 2 dr w supersix.Otherwise stock. What do you think the outcome would be?performance gain? Or will I lose any low end power? Waste of time and money or do I get the green light from all my /6 buddies ??
PostPosted: Thu Feb 12, 2004 1:20 am
I went from a stock exhaust manifold / exhaust system to clifford dual headers joined in a y pipe to a dynomax superturbo muffler with 2 1/4" pipe throughout. I sure noticed a difference....
Word to the wise about headers though, they will make working in the engine bay a bit more of a challenge because you have to be careful not to scratch them. Also, your carb/efi/fuelsystem must be in good tune because running too rich or lean will cause excessive exhaust gas temps and roast the coating on them. If I were to do this all over again I would shoot for dutra duals or dual duals instead. Lots less hassle/headache. If I ever get the cash together I'll get rid of my clifford headers and go for dual duals.
PostPosted: Thu Feb 12, 2004 1:43 am
what do you mean by dual duals??
PostPosted: Thu Feb 12, 2004 1:58 am
Dual duals are where you use Doug's front casting for the rear as well instead of a modified stock manifold. I believe pictures of this are detailed in his article (located in the articles link off of slantsix.org)
PostPosted: Thu Feb 12, 2004 9:18 pm
Dutra Duals sound great, but I don't have the money for them. Hopefully by the time I get my engine running well enough to make the cost of the Duals worth it they'll still be around, right now forking over the money required makes no sense when I have things like throttle issues to figure out(and the stupid carb has been played with).
My car may be slow to sixty, but at least it's been reliably slow to sixty for more than thirty years.
PostPosted: Fri Feb 13, 2004 12:34 am
let's face it..being as it's a 225 slant 6,,how often will I be working in the engine bay ??!!
PostPosted: Fri Feb 13, 2004 12:39 am
Johnny, love the attitude ;) But every nut and bolt that you do wrench on will be a bit more tedious to deal with.
Btw, your handle wouldn't happen to be influenced by the robot Johnny 5, would it?
PostPosted: Fri Feb 13, 2004 12:46 am
u tell me what areas I'll be "working on", and then we'll have some kind of understanding !!!
PostPosted: Fri Feb 13, 2004 11:20 am
nothing sounds meaner than a slant six with headers and dual exhaust, not even a hemi! :shock:
