It is currently Sun Jun 14, 2026 7:20 pm
PostPosted: Wed Apr 07, 2004 11:40 am
Car Model: Valiant V200 225 4dr three on the tree
Hello from Sweden!
Does anybody know if a fueltank from a 1971 Valiant fits on a 1967 model?
Regards Lasse
Lasse
Signet -66 225
Holley 600 Offy-5270 Dutra Dual,regrind. cam 272 0,420 110, head shaved 0.100 slight.ported
MSD6A
A904
7 1/4 3.23
PostPosted: Wed Apr 07, 2004 7:14 pm
Filler neck size and the shape should be the same, there may be some extra vapor return fittings on the 71 tank.
PostPosted: Wed Apr 07, 2004 10:52 pm
OK Tnx!
Lasse :)
Lasse
Signet -66 225
MSD6A
A904
7 1/4 3.23
PostPosted: Fri Apr 09, 2004 9:40 am
skraecken, if you're talking about an A-body then proceede with caution.
i know that 67 barracudas attached the tank with a single strap, while 68 and 69 got two straps across a tank that was shaped a little differently.
I don't know if MaMopar carried the single strap across the line for the A's in 67, but i can tell you with a level of confidence that the dual strap design was carried from 68 till the bitter end on all of the a-bodies.
better to check before dropping the coin IMHO...
-JYH
64 Dart, tank? what tank?
*evil laughter*
