It is currently Tue Dec 23, 2025 6:41 pm
 Post subject: Stock /6 With Headers
PostPosted: Tue Jun 13, 2006 10:21 pm
:?: I have a stock slant that I am going to install clifford headers on(I already have them). What do you guys think I should do about the absence of the heat riser valve and the stock automatic choke-mounting pocket? Since those are a part of the stock manifold what do I do now? :?:
PostPosted: Tue Jun 13, 2006 10:26 pm
Simple. On cold mornings just sit in your car and rev the engine a little for about 10 minutes andd then you should be ok. On warm or hot days it will only take about 5 minutes..hehe
PostPosted: Tue Jun 13, 2006 10:38 pm
Might wanna think about an electric choke.
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
PostPosted: Tue Jun 13, 2006 10:49 pm
Or use a manual choke and the later air cleaner with the hot air "door".
I have welded studs to the #4 header tube and used double nuts to bolt on the auto choke spring assembly, that works.
PostPosted: Wed Jun 14, 2006 9:06 am
I remember seeing a guy selling some kind of warming plate on eBay. I couldn't figure out what it was for at the time, but maybe this is it. I think I found it searching for either "slant 6" or "slant six." It popped up several times over a period of time.
PostPosted: Wed Jun 14, 2006 11:32 pm
i did the same thing. you just have to set the idle right. i would get up in the morning and it would idle at about 450 or 500 rpm, not enough to make the auto tranny work. remember to pump the trhottle once or twice to get some fuel in the manifold. and you will need to learn to drive a cold engine, feathering the throttle and other neat little tricks specific to your car.
zedpapa
1970 dodge dart w/225 /6 bored .040" over, holley 390cfm w/vac. sec., compcams 252s, clifford shorty headers w/2.5" exhaust w/flowmaster, f-body 11" front discs, aluminum A-833OD, 8 1/4 w/3.21 SG
soon to have 5 gears!!!
PostPosted: Thu Jun 15, 2006 11:45 pm
You can buy the Intake Heater Here:RasoEnterprises
(You will need to scroll down a little bit).
I believe his name is Frank Russo or Raso. He is on this board once in a while. I was planning on getting one when I got headers. Looks pretty neat. Seems like a good idea. He also sells some other slant six stuff on his site as well.
Cory
P.S.: Ask him if he has his "special" discount yet, for us /6er's.
-'72 Valiant Sedan, Stock (For Now)
PostPosted: Fri Jun 16, 2006 3:46 am
The heater plate for the intake may help with fuel atomization once the car is warmed up, but remember that the water flowing through the plate will be cold for several minutes after start-up.
-Mac
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
