It is currently Fri May 22, 2026 4:15 pm
PostPosted: Wed Jun 21, 2006 1:35 am
Found a plug on passenger side towards rear of engine between oil filter and oil pressure switch.
Is this a coolant drain plug or oil passage way plug?
Don't see any plugs on drivers side (other than freeze plugs)
PostPosted: Wed Jun 21, 2006 2:53 am
Yep, it's the block coolant plug..........
Finally picked the correct terms to search on and found it in the archives.....................
BTW, the search terms were 'block drain' didn't find anything if coolant or plug was in the search.........
PostPosted: Wed Jun 21, 2006 2:24 pm
I had a dickens of a time getting mine off and had to put a flame to it. put some anti seize on the threads to make removal easy next time
PostPosted: Wed Jun 21, 2006 3:50 pm
if you're feeling frisky, you can buy an aftermarket temp gauge and put the sender into that drain plug.
i trust the temp in the car, but the aftermarket ones give a little bit more detailed status of the water temp.
70 Plymouth Valiant 4dr
PostPosted: Wed Jun 21, 2006 4:02 pm
The water is cooler at that drain plug than the normal temp sensor location, so it's not apples to apples......
PostPosted: Wed Jun 21, 2006 4:15 pm
best to put a radiator petcock valve in that hole. a nicer way to drain the block.
-james
PostPosted: Wed Jun 21, 2006 6:37 pm
I've seen James' $bling$ motor with the petcock - nice.
PostPosted: Wed Jun 21, 2006 7:21 pm
Some Idiot(me) painted mine closed. I cant get that sucker to move at all. :roll:
PostPosted: Wed Jun 21, 2006 7:40 pm
Mine still has the original paint.....
But I bet it hasn't moved for 42.5 yrs. :roll:
