It is currently Tue Dec 30, 2025 7:26 am
PostPosted: Thu Jul 06, 2006 1:44 pm
What is the curb weight of a 67 Nochback Barracuda? Also what 1/4 mile time should I expect from a stock setup or just the super six upgrade? One more thing. Does anyone know the CDA of this car?
PostPosted: Thu Jul 06, 2006 4:24 pm
What kind of gears do yoou have? I turned a best of 19.17 with my Duster which ways 3300 pounds, has 2.76 gears, super six, 2 1/4 exhaust and every thing else stock. I am about to do distributor recurve which will hopefully get me into the 18's.
Tell us some more specifics about your car in order to give you a more accurate estimate. Slant Cecil turned 18's in his bone stock 66 Valiant.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Fri Jul 07, 2006 8:50 am
ratio 2.76.
Do you know the CDA (drag coefficient) for this car?
PostPosted: Fri Jul 07, 2006 12:16 pm
It would not surprise me to see a stock notchback run mid 18's. 67 notches were pretty much the lightest 67-76 A body made.
CDA is probably not that good with the big, flat grille and notch window. :shock:
PostPosted: Fri Jul 07, 2006 7:12 pm
Yeah, I agree. You will probably see 17- 18 second times with a Supersix and a tweaked distributor. It might run that with a 1-barrel. Cecil did it with his Valiant. All depends on your state of tune.
Make sure that your throttle blade is opening all the way. Most factory cars I have seen only open about 80% stock. May have to do some adjusting.
82 D150-225/727
Users browsing this forum: Ahrefs [Bot] and 1 guest
