It is currently Thu May 28, 2026 4:39 pm
PostPosted: Fri Apr 06, 2007 4:01 pm
what weight of motor oil should i use for initial break in of my engine after it is completed and installed? should i use any additives to ease the break in? and what kind if any?
thanks
russ
PostPosted: Fri Apr 06, 2007 4:28 pm
I would use any reputable brand of conventional, non-synthetic 5w-30 with no extra additives, and a Wix or Purolator filter. I would change the oil at 500 miles, then at 1000 miles, then at 3000 miles, probably changing to 10w30 at that point.
PostPosted: Fri Apr 06, 2007 4:43 pm
I would agree with Dan on the oil choice...I work in a parts store and you hear just about every old wives tale there is. I've heard some guys say that non-detergent 30 weight is the best break in oil, but they never really have any data top back it up. Consider that new parts (like rings and freshly honed cylinder walls) will be bedding in and I think a high detergent oil with dispersants makes sense to keep all the contaminants and metal swarf in solution until that critical first oil change. Did this motor get a new cam and lifters? If so I'd follow the cam manufacturers break in instructions TO THE TEE! Breaking in a new cam and lifters is a critical process and I've read that what you do in the first thirty minutes of running a new engine can determine the life of your cam. I read that it is actually work-hardened in the first thirty to forty five minutes and getting this right determines whether the cam lives a long and happy life or dies early. Davey
PostPosted: Fri Apr 06, 2007 4:47 pm
I meant to say that cam lobe faces and lifter faces are work hardened in the first thirty to forty five minutes. The entire cam is case hardened at casting I think, and then the grinding of lobes cuts into the hardened shell on the lobes, which are work hardened on first run. Just to clarify...Davey
PostPosted: Fri Apr 06, 2007 4:51 pm
:shock: :shock:
Absolutely! Factory fill even back in '60 was detergent oil. And a thin oil is much better than a thick one, since you've gotta get oil into brand new, very tight clearances.
Yep. Hope you applied break-in paste to the cam lobes. Consensus seems to be that it's critical to vary the engine RPM for the first 30 minutes, rather than letting it idle or run at any constant speed for much of any length of time. Also critical to get the engine up to operating temperature ASAP, so the old notion of running-in the engine with the draincock cracked and a garden hose in the radiator neck is right out of the question.
PostPosted: Fri Apr 06, 2007 6:04 pm
Thanks for all the info guys. Break in paste? I put moly on the lobes. The stuff that was supplied with my Erson cam. Is this the right stuff? Right now i only have the crank and cam in it, so its not to late to fix it if im wrong.
russ
PostPosted: Fri Apr 06, 2007 7:06 pm
I just picked up my assembled shortblock today and was told to use Rotella oil 20w oil for cam break in, then a good 10w-30 for initial engine break in.
Does 20w sound right for the cam? Everything I've read says 10w-30.
PostPosted: Fri Apr 06, 2007 7:07 pm
Yep!
PostPosted: Fri Apr 06, 2007 7:09 pm
I would call this bad advice all around. Spend much of any time listening to the guys who really know the science and aren't just trying to sell something over on BITOG (the vehicle fluids board), and you'll find that Rotella is generally held in low regard.
PostPosted: Fri Apr 06, 2007 7:24 pm
SSRN National Champion
If has a new Compcam in it call them ask what oil to break it in with. I know of one racer that wiped a lobe right off a slant cam. Lets just leave it there.Compcams said you did not use the right breakin oil. Better check the cam maker or engine builder than just opinions. Thanks Ron Parker. :D
Bagels On Juice Im Bamboozled
Bagels Juiced Im Bamboozled
PostPosted: Fri Apr 06, 2007 7:32 pm
So Dan I guess that your not a beliver in what Crane has been saying
for some time?
http://www.cranecams.com/pdf/548e.pdf
here is anouther one from the Comp cam site
http://www.compcams.com/Community/Artic ... 1578676008
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Belveder A318 727 4d
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4spOD
Old iron or no iron
PostPosted: Fri Apr 06, 2007 7:39 pm
I am truly ate up with it I know, but I really enjoy talking about this stuff and thinking about it. If you want to see what I read about cam break in and work hardening of cam faces and moly, go here:
http://yarchive.net/car/cam_break_in.html
These guys are smart, and they are down to earth. John DeArmond agrees with Erson and SlantSixDan about the moly...it is a great break in lube for your cam. Again, with the moly and closely following the break in procedures, you can't go wrong. Cheers! Davey
PostPosted: Fri Apr 06, 2007 8:04 pm
The cams are billit steel not case harden. They are then ground to the profile . Again I would go with the cam manufactuer specs and type of break in oil rather than to listen to ron parker or bill bob or dan. Think Who is The Funny Man. Thanks Ron Parker :D
PostPosted: Fri Apr 06, 2007 8:10 pm
Erson recommends the use of GM "engine oil supplimemnt" during cam break in.
PostPosted: Fri Apr 06, 2007 8:25 pm
for some time?
Their advice and mine aren't all that different. They list Rotella as an OK alternative, and (to clarify my position) using it won't cause a disaster, but there are much better oils on the market.
As far as additives, yep, I'd forgotten about the Zn-based additives all the major automakers supply (can get it over the counter from a Mopar dealer, GM dealer, etc.), and it's probably a good idea to use.
But straight 20-weight? Naw, I don't buy that.
