It is currently Wed Dec 24, 2025 1:08 pm
PostPosted: Mon Apr 09, 2007 5:30 am
Can a slant with a stock cam handle a holley 390 or does it put to much gas in the cylinders
PostPosted: Mon Apr 09, 2007 7:22 am
I don't know from personal experience but I would think, since the 390 has vacuum secondaries, that it would work on a stock 225. Can you use all of that CFM - I doubt it.
'63 Valiant V200 Convertible
225 Aluminum Block
PostPosted: Mon Apr 09, 2007 8:16 am
A 390 vacuum secondary carb can be adjusted to work on a stock SL6 but it is not going to work well right out of the box.
Usually they need more accelerator pump shot and a high rated power valve.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 14 guests
