It is currently Mon Dec 22, 2025 3:51 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Tue Apr 10, 2007 4:58 am
Earlier in this post I asked if the manifold was for a "super six" 2bbl or 1bbl - to clarify - is the manifold to exhaust pipe connection larger in diameter for the 2bbl ? Or is the diameter the same for both the 1bbl and 2bbl manifolds ?
thanks jeff
PostPosted: Tue Apr 10, 2007 7:01 am
Same. There is no difference between the exhaust manifolds used with 1bbl and with 2bbl setups.
PostPosted: Tue Apr 10, 2007 12:17 pm
And if you are wondering about this manifold, the exhaust pipe ID is 2" at the flange. I just measured it today.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Wed Apr 11, 2007 5:40 am
Thanks :!:
 Post subject: A-1 Exhaust Manifold
PostPosted: Wed Apr 11, 2007 4:30 pm
I also purchased a "A-1" exhaust manifold. The casting was very poor and actually had sand holes in the casting below the heat riser. I repaired it with J B Weld prior to installation and it's been fine so far. It also had the "China" name cast in to it. If I had it to do again, I would buy one from a junk yard !!!
Users browsing this forum: Ahrefs [Bot] and 6 guests
