It is currently Tue Dec 23, 2025 2:45 am
 Post subject: Air Cleaners housing.
PostPosted: Thu Sep 18, 2008 10:00 am
would a Pro-Flo® 1000 Series Reusable Air Cleaner fit on a 2 barrel carter bbd under the hood of a 1970 plymouth valiant.
or where could i find some awesome air cleaner housings for a 2 BBL?
PostPosted: Thu Sep 18, 2008 10:01 am
How are we defining "awesome" here? What exactly do you want to accomplish?
 Post subject: Air Cleaner housing
PostPosted: Thu Sep 18, 2008 6:25 pm
i just need a air cleaner that looks nice and if that one will fit under the hood
PostPosted: Thu Sep 18, 2008 8:46 pm
IMO nothing looks nicer than a stock, gloss black air cleaner with the super six decal on top.
These engines with all the chrome and blue and red fittings just look like cheap aftermarket decorations.
PostPosted: Fri Sep 19, 2008 6:39 am
I think you'll find that slanters tend to be a more down-to-earth when it comes to modifications as opposed to most typical "hot-rodders". There's been some discussion on this forum regarding reusable air filters (do a search), much of which was negative.
Like a lot of slanters, I went with the stock air cleaner because of function, and made sure the flapper valve for manifold heat works, because I want the engine up to operating temps as quickly as possible for best mileage. I also hooked up a fresh air duct for a denser charge after warm up for best power. Open element air cleaners, while sexy, aren't the most efficient.
This flies in the face of most hot rodding, whereby the first thing the typical owner will do is slap on an aftermarket chrome air cleaner. Lots of slanters still run open element air cleaners, but fewer, I think, than typical car guys.
vm
PostPosted: Sun Sep 21, 2008 8:00 pm
I wouldn't go with a Pro-Flo, a.k.a. No-Flow on anything. You can run any 4 barrel air cleaner on your 2 barrel, as long as you have an adapter. Most parts stores should carry them. I ran a 2 barrel on my 70 Nova for a while, and used an Edelbrock air cleaner. I had a 2 to 4 barrel adapter on it. That's all you need, and you can run any air cleaner.
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Tue Sep 23, 2008 7:15 pm
I posted these pics a while back when this topic came up then. I cut the center out of the stock super six base (there's almost a natural seam to follow) then ground it smooth and used a factory early bell with the corresponding filter. I like the look and proportions of these units; you don't need to bore holes in the top for an open element effect but I did and I think it's slick.
Dan, I still haven't forgotten but I also haven't stumbled on another super six assembly.
PostPosted: Tue Sep 23, 2008 10:16 pm
i cut the center out a one barrel base for mine
87 d150 2bbl carb 225
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
89 f450 diseal 4x4 dually 5sp
PostPosted: Wed Sep 24, 2008 4:37 pm
I had a beautiful 11" K&N air cleaner on my Valiant when it left for texas... Since then my dad replaced it with a huge, generic 14" one. The 11" one scaled so beautifully with the rest of the engine... It looked similar to where people have dual 1bbl's and thus have 2 air cleaners, cept it was only one.
-Anthony
1962 Plymouth Valiant Signet 200
